Sometimes if I join two or more switchs (all in access port mode) in a mikrotik bridge I see weird behavior such machines that stops working or sometimes if I have three switchs then switch1 and switch 3 is working normally and switch 2 stop the communication.
Any stp/rsp protocol is disabled in mikrotik bridge. If I enable I see the same behavior. The problem is not happening if I join switch using a bare wire cable.
Connecting using direct cables is not the same the using a bridge however we expect the same result in final. So maybe some abnormal work of stp/rsp switchs protocols if I join using a mikrotik bridge?
Is there maybe any bridge firewall rules to solve/minimize the problem?
