Jump chain question
Hey,
i’ve surfed a lot of wikis, and web, and still havent found right answer so:
if i’ve have jump to another chain, what happens when chain comes to the last rule, does it jump back after jump, or it continues going, and i should use return ?
If you need to put 100 rules inside your main rules (example: virus rules).. you create a chain “virus”. Then you jump to virus and you return to the next line you “jumped”.
It’s not like a “jump” the next 10 lines..
No, i understand, but my idea is that, if i jump to first line or Virus, will it return to line after jump rule, or it will go further from all jump rules?
chain 1
chain 1
chain 1
jump virus
jump virus2
chain1
chain1
chain1
this will execute chain1 till line4, then execute all virus rules, later all virus2 rules and continue with the last 3 chain1 rules.
oh now i see,
if i have
input
input
input
forward 1
jump to virus
forward 2
virus
virus
virus
i should have Return after last virus rule, to return to forward 2
otherwise it will finish after last virus rule?
return is set by default if you don’t put nothing…
oh, now i get it :slight_smile:
it will return auto to rule after jump.
thank you.
