hello, how can you disable the reset button in the last versions of routeros?
For Winbox access are the following steps
System → Routerboard → Settings Button
Uncheck Jump Reset and ok
Option - New Terminal or ssh
system routerboard settings set enable-jumper-rese
t=no
is there any limitations for that, or any ROS supports this feature?
In the menu setting this is what appears now
