Jumper settings for 24v on RB532
Hi:
Could anyone tell me what jumper settings they are using when conecting the RB532 to a 24v power supply?
In my case we use 2 12v batteries to power them, before we where using 3 6v, and on one of the sites a 532 got fried after changing from 18 to 24…
Jorge
You can use 25V-56V Jack and short the JP7 jumper.
All should work, the only problem could be if you will use it with more than one high power card - it could reboot.
Regards
