So basically the the mikrotik using port 16 on the juniper as uplink so we can configure and get link ready, however it doesnt reconize it
The Juniper Port status still is “Link Down”. However lights on both ports are blinking , juniper and mikrotik
Any idea? Do we need to change some setting on the mikrotik?
I read the ports are programmable so can be used as you need, as uplink for mikrotik device and also for uplink for others
