Just a NAT device, nothing more - RB2011L-in
Hey guys,
I am rather new to Mikrotik.. Lets say totally new.
I have a setup with some servers controlled by there own firewall (TMG2010) and other devices that needs NAT in front of it.
From my ISP i recived a block /29 that allows me to have 5 usable adresses to work with.
I want my router to be able to do the following;
  • My first port is the uplink to ISP. This is to be managed from the outside.
  • Port 2 is a slave with a device behind it that has a static IP. (out of the 5 from my ISP) Router should be manageable from that device.
  • Port 3 is a slave with a device behind it that has a static IP. (out of the 5 from my ISP) Router should be manageable from that device.
  • Port 4 is a slave with a device behind it that has a static IP. (out of the 5 from my ISP) Router should be manageable from that device.
  • Port 5 is a slave with a device behind it that has a static IP. (out of the 5 from my ISP) Router should be manageable from that device.
As the network behind the Mikrotik has its own firewall i need the Mikrotik to be transparant.
However I do need to specify what outside IP adress is able to manage the router.
Is this possible?
I can post the current config if that helps, i have been trying some stuff so far.
Let me know if this is in any way unclear, i will try to specify what and where i can!
Regards, René
Are the connected devices are destined to have the ISP delivered public IP’s or do you want the Routerboard to have the IP’s and use NAT?
Yes they should hold the IP of the ISP.
In that case just bridge all the interfaces, or use master-port setting
So,
If I set port 2-5 as slave this should work?
How about the firewall then? Are there any rules to use or can i disable it in its whole.
When trying to set ether2 {Master Port ether1-gateway} i get back error:
Could’t change interface - already in bridge(6)
Can I delete the bridge?
=------------------------------------------------------------update-----------------------------------------------------------------=
Okay, i have unchecked ether2 from bridge and am able to bind ether2 with Master port ether1-gateway.
Also did the same for ether3, ether4 and ether5.
I can now ping from all ip adresses to all adressen so that works.
However, the firewall is still active now…
Any way to disable that?
Hmm looks like not much response on this one.
Ill leave the firewall on for now. Gonna make a new thread on how that one works out.
Thanks for the help though.
Here’s a thread with a similar setup that might help:
http://forum.mikrotik.com/t/how-do-i-setup-router-for-public-29-address-space/71870/1
