Just Can't Get PPTP server to work Help!!
I have been tryin to get pptp working with a w2kserver for 3 days!!
can anyone spot what I have done wrong?
Terminal vt102 detected, using multiline input mode
[admin@Rugby Router 1] > admin
ERROR: no such command or directory (admin)
[admin@Rugby Router 1] > ppp
[admin@Rugby Router 1] ppp> sec
[admin@Rugby Router 1] ppp secret> pri
Flags: X - disabled
NAME SERVICE CALLER-ID PASSWORD PROFILE REMOTE-ADDRESS
0 nick pptp nnnnnn pptp-profile 0.0.0.0
[admin@Rugby Router 1] ppp profile> pri
1 name="pptp-profile" local-address=pptp-pool remote-address=pptp-pool
session-timeout=0s idle-timeout=0s use-compression=yes
use-vj-compression=no use-encryption=yes require-encryption=no
only-one=no change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0
incoming-filter="input" outgoing-filter="output" dns-server=""
wins-server=""
[admin@Rugby Router 1] interface pptp-server> pri
Flags: X - disabled, D - dynamic, R - running
NAME USER MTU CLIENT-ADDRESS UPTIME ENCODING
0 pptp-in1 nick
[admin@Rugby Router 1] ip pool> pri
NAME RANGES
0 Admin-pool 10.101.0.100-10.101.0.199
1 pptp-pool 10.102.0.50-10.102.0.99
PPTP is’nt working with me since version 2.8.13.
The same settings on 2.8.4 work just fine.
And as far as i recall 2.8.12 used to work fine.
We need a quick fix for that.
The error message is 734 in XP.
ppptp is working as expected for us (2.8.13 and 2.8.15).
maybe a trace will help: http://www.modemsite.com/56k/ppp.asp
there is also an issue with some clients concerning microsofts encryption method but it will be as error message in the trace file too.
i would try establishing a simple pptp connection without using profiles and adding profiles and pools later.
(btw: macos x ppp-client shows a quite good log)
