Hi all, Im a complete beginner to RouterOS and network setups. Ive installed L009UiGS and have the following config.
Internet is connected to LAN port, not to WAN (eth1), DHCP runs from wifi antenna (ISP) and the internet doesnt work if I plug it into eth1 even if DHCP on the router is switched off.
I have static public IP with NAT on the antenna to access server beyond the router from outside.
I cannot ping anything outside the LAN from the router, also updating the firmware doesnt work as well as ntp servers. Any help welcome.
# 2024-07-16 08:33:07 by RouterOS 7.14.3
# software id = 1B7B-8UDF
# model = L009UiGS-2HaxD
# serial number = ***
add admin-mac=D4:01:C3:D1:D6:3E auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=INTERNET
set [ find default-name=ether7 ] comment=PRACOVNA
set [ find default-name=sfp1 ] disabled=yes
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.country=Czech .mode=ap .ssid=514 disabled=no security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0 .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wifi1
add address=192.168.1.11/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.99 gateway=192.168.0.99 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,10.1.0.1,10.1.0.254
/ip dns static
add address=192.168.1.11 comment=defconf name=router.lan
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
add action=accept chain=input comment="default configuration" connection-state=established,related
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Prague
/system note
set show-at-login=no
/system ntp client
set enabled=yes mode=broadcast
/system ntp client servers
add address=ntp.cesnet.cz comment=CESNET
add address=time.google.com comment=GOOGLE
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
