Please check in my configuration PCC, only sailed for a while WAN
/ ip address
add address=10.1.1.1/24 network=10.1.1.0 broadcast=10.1.1.255 interface=pppoeserver
add address=190.186.56.170/29 network=190.186.56.168 broadcast=190.186.56.175 interface=wan1
add address=192.168.1.5/24 network=192.168.1.0 broadcast=192.168.1.255 interface=wan2
/ ip firewall mangle
add chain=input in-interface=wan1 action=mark-connection new-connection-mark=wan1_conn
add chain=input in-interface=wan2 action=mark-connection new-connection-mark=wan2_conn
add chain=output connection-mark=wan1_conn action=mark-routing new-routing-mark=to_wan1
add chain=output connection-mark=wan2_conn action=mark-routing new-routing-mark=to_wan2
add chain=prerouting dst-address=190.186.56.168/29 action=accept in-interface=pppoeserver
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=pppoeserver
add chain=prerouting dst-address-type=!local in-interface=pppoeserver per-connection-classifier=both-addresses:3/0
action=mark-connection new-connection-mark=wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=pppoeserver per-connection-classifier=both-addresses:3/1
add chain=prerouting dst-address-type=!local in-interface=pppoeserver per-connection-classifier=both-addresses:3/2
action=mark-connection new-connection-mark=wan2_conn passthrough=yes
add chain=prerouting connection-mark=cotas1_conn in-interface=pppoeserver action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=cotas2_conn in-interface=pppoeserver action=mark-routing new-routing-mark=to_wan2
/ ip route
add dst-address=0.0.0.0/0 gateway=190.186.56.169 routing-mark=to_wan1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_wan2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=190.186.56.169 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=wan1 action=masquerade
add chain=srcnat out-interface=wan2 action=masquerade
Check my routes
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 190.186.56.169 1
1 A S 0.0.0.0/0 192.168.1.1 1
2 A S 0.0.0.0/0 190.186.56.169 1
3 S 0.0.0.0/0 192.168.1.1 2
4 ADC 10.1.1.0/24 10.1.1.1 pppoeserver 0
5 ADC 190.186.56.168/29 190.186.56.170 wan1 0
6 ADC 192.168.1.0/24 192.168.1.5 wan2 0
help please
Gerrynet
