Still loving my MikroTik Chateau Pro AX and have some questions about it:
- Where is the Gratuitous ARP option? I saw it once, but then lost it. I want to disable that completely and only allow 2 ARP types - request and reply. This is mostly because some clients, such as Apple TV, impersonate other devices by design (via Bonjour) and are sometimes detected as spoofs.
- How to get DoH to work without any cleartext DNS bootstrapping? IP URL (such as https://1.1.1.1/dns-query) is the way to do it, but router is unable to resolve any addresses with any DoH IP URL’s.
- How do I perform full and utter sanitation/purge/scrub? This router preserves backup files, logs, and some other data after factory reset.
- Are there any plans to add some wizards for some basic functions, such as VLAN creation? I knew what I was getting when I bought this router and didn’t mind going through learning process of creating new bridges, interfaces, etc., but I think there should be a simple wizard to be utilized first and then configure manually if necessary.
- Are there custom configurations that can be downloaded from some kind of database? For example, there is factory/default (defaultcon) configuration. I wish there was one just like that, but have each port assigned untagged VLAN by default.
