I finally had my mAP running properly, and one of the last things to do was add the NTP client package, which is supposed to be part of the “MAIN” package. And that’s when things went to sh!t !
The mAP was running version 6.x (don’t recall exact version), and the built in package updater said that was the latest stable version. But on the website I saw version 7.16.2 was the latest stable. So I downloaded the MIPSBE 7.x version, copied to the mAP’s files section, rebooted, and tada I was upgraded.
But, on startup the mAP kept reporting a script error, eventually giving up saying it can’t find any wireless adapters. and if I try to add the wireless interface manually it doesn’t see it!
What have I done!! I should have left it alone, but I’m stuck. Can someone tell me what to do next? I tried adding the EXTRAS package thinking maybe the wireless driver was in there. Nope. I tried the “DOWNGRADE” button from the packages section, but after a reboot still running the same version.
Don’t worry , it happens to everyone, it is the second mistake that happens to everyone (the first one is losing access to the device when fiddling with settings and needing to reset it).
The mAP should run fine with latest 6.x version (6.49.17 if I recall correctly) whilst with v 7.x versions it may be a bit slower, as the architecture and processor/resources are a bit tight for 7.x.
Upgrade from ROS6 is to ROS 7 via on-line upgrade, has a specific path to follow
Upgrade via the usual channels stops at last ROS 6 version
There is an extra upgrade path called “Upgrade” that brings 7.12.1 as version.
From 7.12.1 onwards you can go further in the ROS7 upgrade paths.
7.12.1 is needed for changing the package list in 7.13, including the split off “wireless” package (WLAN driver) , or even the “wifi-qcom/wifi-qcom-ac” package (wifi driver)
It’s in the release notes since 7.13 and has been repeated many times in the RN
Notice - Starting from RouterOS version 7.13, significant changes have been made to the RouterOS wireless packages. This is done due to a new product development which will require more disk space for hardware drivers so we had to split it in order to maintain old products alongside the new ones. More wireless packages are yet to come.
1. When upgrading by using "check-for-updates", all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always.
