Karma Hotspot
Good Day All,
Is it possible to have RouterOS by some means of a script, or perhaps another idea, to automatically login to a Karma hotspot?
You may have heard of the new hotspot called “Karma”, their site is www.yourkarma.com, they have a mobile hotspot which is meant to be shared by other people, you get more data that way too. Anyway to the point, they have an SSID with no security, and unfortunately you cannot configure this security manually.
The hotspot works like many, although this one requires you login with your karma account, and then gain access.
Ultimately, I’m trying to figure out a way for the router board to automatically login to the Karma Hotspot.
I have a RB951Ui-2HnD which I am setting up in station mode, connecting to the Karma Hotspot, and then using this wireless signal to share to other ethernet devices. The problem I am facing is I have to go manually on a computer to login, and then things go online. I am trying to remove this manual step to login, and make it autonomous when necessary.
Any help will be appreciated with this.
Thank you!
Try to find out if it’s possible to login via a URL (with token or encoded credentials as part of the URL)
