Keep terminal session alive after disconnecting winbox
Like the title says. On linux I normally either use “screen” or I launch a command in background, with &. How do I do it with mikrotik? Like to keep open an ssh connection.
Whatever command you want to be persistent, instead of typing it into the terminal, type it into a script and then run the script. It will keep running even after you disconnect winbox.
Sent from my iPhone using Tapatalk
I will try, thanks!
edit: it does not seem possible to handle interactive sessions properly via scripts. http://forum.mikrotik.com/t/remote-ssh-via-script/64915/1
I’ll have to use fastkeys and other systems to do that.
Yeah, OK… if the command you are running has even the potential of ever reading stuff from user-input, it won’t be allowed.
See this posting for my own bugaboo related to this topic.
