keepalive-timeout
hi
i use MT as ADSL BRAS and the problem is that most users suddenly disconnected from BRAS without any reason.
i think it should be keepalive-timeout.
what is the best value of “keepalive-timeout” for pppoe clients. and is it good to set this value to 0 ?
how about “one-session-per-host” ?
can we use “one-session-per-host” in order to prevent pppoe clients to connect more than once?
thanks.
please help :frowning:
and what’s in Log?
it’s realy hard to trace the log because there are so many transaction at the moment.
here is the log
Jun/26/2010 15:30:11 pppoe,ppp,info,account er7712 logged out, 13999 3837760 25365835 20107 24951
Jun/26/2010 15:30:12 pppoe,ppp,info : terminating… - disconnected
Jun/26/2010 15:30:12 pppoe,ppp,info : disconnected
Jun/26/2010 15:30:11 pppoe,ppp,info,account er4672 logged out, 11489 7887362 37315433 80206 32967
Jun/26/2010 15:30:12 pppoe,ppp,info : terminating… - peer is not responding
any idea about “keepalive-timeout” and “one-session-per-host” ?
dear Chupaka haven’t you seen such this problem before?
nope, I don’t use PPPoE…
you may try to increase keepalive-timeout. if it won’t help - try to set it to zero (or make it big) and enable one-session-per-host, but I’m not sure whether it works with non-local authorization. also, check for errors on your ethernet interface
