I’m looking for a way to retain the interface name when I have to swap out a bad radio card.
The first time I did it, I noticed that the interface came up as some generic name, and every other part of the configuration that referenced the old interface was “(unknown)”. When I renamed the generic name to the previous interface name, it didn’t affect the other portions of the configuration, and I had to rename all of them one by one.
The next time, I thought I would be clever, and just before shutting down the router I changed the MAC address of the bad interface to the MAC address of the card I was about to insert, thinking I could fool the router into believing nothing had happened. It didn’t work.
How does everybody else solve this problem? Don’t tell me everybody hand-corrects the entire configuration after replacing a radio card?
Yup. Sadly I can’t see any way to keep the config.
I don’t have that issue with radio cards, but with short lived VLAN interfaces. You bring it back with the exact same configuration (you can even copy/paste the previous config, and these are virtual!) and all references are dead. Probably because on generation/insert a new unique key is generated in the background.
I don’t see any way in RouterOS to work around that.
im almost done with a script that will wrap up the interface in a dummy bridge, let you swap the card, and then unwraps the config back to the physical interface. Lame I know. Is routeros using udev?
since its been a year or more since I’ve worked on it, I am going to share it here and hopefully someone can finish it for me. Once done we can make a wiki page for it. Probably 2 scripts, one for before and one for after.
# Written by Sam Norris
# Allows swapping of interfaces without the hassle of reconfiguring everything.
# --- BEFORE ---
#0. Make a backup : )
#1. Find all real interfaces
#2. Add new bridge interfaces
#3. Add real interface into corresponding bridge interface
#4. Reconfigure IP addresses
#5. Reconfigure Firewall Filters
#6. Reconfigure NAT Translations
#7. Reconfigure Mangle Rules
# --- BEFORE ---
# Make a backup
/system backup save name="before-interface-swap"
# Now loop thru each real interface
:foreach realinterface in=[/interface ethernet find] do={
# Process some vars for speed.
:local OldName [/interface ethernet get $realinterface name]
:local NewName ("$OldName" . "-temp")
# Add an empty bridge for each real interface we find.
/interface bridge add name="$NewName" comment=[/interface ethernet get $realinterface mac-address]
# Add the interface to its temporary bridge.
/interface bridge port add interface="$OldName" bridge="$NewName"
# Change the IP ADDRESSES from the real interface to the temporary bridge.
:foreach ipaddr in=[/ip address find interface="$OldName" dynamic=no] do={
/ip address set $ipaddr interface="$NewName"
# -- FIREWALL FILTERS --
:foreach rule in=[/ip firewall filter find in-interface=$realinterface] do={
/ip firewall filter set $rule in-interface="$NewName"
:foreach rule in=[/ip firewall filter find out-interface=$realinterface] do={
/ip firewall filter set $rule out-interface="$NewName"
# -- NAT TRANSLATIONS --
:foreach rule in=[/ip firewall nat find in-interface=$realinterface] do={
/ip firewall nat set $rule in-interface="$NewName"
:foreach rule in=[/ip firewall nat find out-interface=$realinterface] do={
/ip firewall nat set $rule out-interface="$NewName"
# -- MANGLE RULES --
:foreach rule in=[/ip firewall mangle find in-interface=$realinterface] do={
/ip firewall mangle set $rule in-interface="$NewName"
:foreach rule in=[/ip firewall mangle find out-interface=$realinterface] do={
/ip firewall mangle set $rule out-interface="$NewName"
# -- QUEUES --
:foreach queue in=[/queue tree find parent="$OldName"] do={
/queue tree set $queue parent="$NewName"
:foreach queue in=[/queue simple find interface="$OldName"] do={
/queue simple set $queue interface="$NewName"
# -- DHCP SERVERS --
:foreach rule in=[/ip dhcp-server find interface="$OldName"] do={
/ip dhcp-server set $rule interface="$NewName"
# --- AFTER ---
#1. Find all bridge interfaces
does comment-$MAC$ exist in system now?
if so,
set name on interface to original
change interface name to original ? (strip-temp) ?
reconfigure rules
remove bridge ports
remove bridges
if not, leave in bridge ?
