ashish
September 22, 2007, 8:51am
1
Hello All,
I am getting this error after boot my routerboard . I have connected it with serial.
RouterBOOT booter 2.5
RouterBoard 133
CPU frequency: 175 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Kernel unaligned instruction access in unaligned.c::do_ade, line 574:
$0 : 00000000 00000004 00000017 802db238 802e0000 013ab59d 00000001 82e40000
$8 : 810fd924 802adc79 802e0000 00000000 81074e34 fffffffe ffffffff 00000010
$16: 029b9382 00000001 802e0000 802e0000 802adc78 82e40090 00000000 00000000
$24: 00000003 81063b44 82e40000 82e40018 80720000 00000001
Hi : 0064b4ff
Lo : 0a958f03
epc : 00000001 Not tainted
Status: 10008c02
Cause : 10800010
PrId : 0001800b
Process (pid: -2132549472, stackpage=82e3e000)
Stack: 00000102 ffffffff 00000000 ffffffff 029b9382 802e0000 8010bf4c
10004c91 80e401b0 00000000 00000000 801109b4 802e23d0 802e0000 00000000
810fd924 802adc78 00000000 00000000 80710000 8010c144 802a0000 80262574
10004c91 801151e4 8010e388 10008000 10008c00 80259bb8 00004001 802e0000
802e0000 802e0000 02000010 8011f5a8 ffffffff 00000000 00000004 0000001e
00000029 …
Call Trace: [<8010bf4c>] [<801109b4>] [<8010c144>] [<80262574>] [<801151e4>]
[<8010e388>] [<80259bb8>] [<8011f5a8>] [<8026bc0d>] [<801cba38>] [<801cba3c>]
[<8011f5a8>] [<801109b4>] [<801151e4>] [<80262574>] [<801151e4>] [<8010e388>]
[<8011f5a8>] [<801151e4>] [<8010e388>] [<801151e4>] [<8011f5a8>] [<801109b4>]
[<801151e4>] [<80262574>] [<801151e4>] [<8011f5a8>] [<801151e4>] [<8010e388>]
[<801151e4>] [<8011f5a8>] [<801109b4>] [<801151e4>] [<80262574>] [<801151e4>]
[<8010e388>] [<8011f5a8>] [<801151e4>] [<8010e388>] [<801151e4>] …
Code:<4>unaligned data access at 0x80108a90
: Forwarding exception at [<80108a90>] (8025a944)
(Bad address in epc)
Kernel panic: Aiee, killing interrupt handler!
In interrupt handler - not syncing
WHAT IS THAT AND HOW TO RESOLVE
ASHISH
uldis
September 24, 2007, 9:26am
3
Upgrade the Routerboards bios; reinstall with Netinstall.
ashish
September 26, 2007, 11:23am
4
a simple question
HOW…???
coz, its geting IP from netinstall utility, but routerboard not detecting in utility…and how to upgread BIOS…only two option i am geting 1. from ethernet 2. from serial. what will be the path of the file…i dont know what to do.
Please help me out
ASHISH.
sergejs
September 26, 2007, 1:37pm
5
Please, post your output when router is detected and booted from netinstall.
ashish:
Hello All,
RouterBoard 133
Memory size: 32 MB
Hi : 0064b4ff
Lo : 0a958f03
Status: 10008c02
Cause : 10800010
PrId : 0001800b
00000029 …
ASHISH
Can anyone explain to me how i go about doing exactly what Ashish did? I have the serial cable? what program did he use? how do you do it?? This would help out my troubleshooting a hole lot… -Jordan
Jordan, it is Terminal emulation program.
HyperTerminal, SecureCRT on Windows, Minicom on Linux etc.
You have to use correct settings for application,
http://wiki.mikrotik.com/wiki/First_time_startup
