Kernel Panic error after routeros upgrade
I was upgrading my RB133 router with routeros-mipsle-6.0. The routerboard now wont start and keeps giving me the following error.
Any assistance will be appreciated.
ERROR MESSAGE
RouterBOOT booter 2.7
RouterBoard 133
CPU frequency: 175 MHz
Memory size: 32 MB
Boot configuration reset, applying defaults
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000001 00000000 00000001
$ 4 : 81d36000 00000004 803d0000 00010000
$ 8 : 73666873 81d3616c 00000000 81c0d4c0
$12 : 810425e0 810425e4 00000000 00000001
$16 : 81d36000 803e3f60 8020eb14 81c92ae0
$20 : 00000000 00008001 00000001 81c92ad0
$24 : 00000000 00000000
$28 : 81c20000 81c21cf0 ffffffea 8020ea18
Hi : 0000000b
Lo : 00000000
epc : 8020ea10 squashfs_kill_sb+0x14/0x38
Not tainted
ra : 8020ea18 squashfs_kill_sb+0x1c/0x38
Status: 10008c03 KERNEL EXL IE
Cause : 90800008
BadVA : 00000000
PrId : 0001800b (MIPS 4Kc)
Process swapper (pid: 1, threadinfo=81c20000, task=81c1c000, tls=00000000)
Stack : 00000000 81d0a005 81c0c7b8 00000000 81d36000 801b350c 81d36000 00008001
8020eb14 81c92ae0 00000000 81d36000 ffffffea 801b3c80 81c92ae0 80428b58
801b2df4 80430000 81c0b6c0 81c0b6c0 803e3f60 803e3f60 81c92ae0 801b4918
81d0d000 00008001 ffffffea 803e3f60 81c92ad0 81c92ae0 81c0b6c0 803e3f60
81c92ad0 801cba44 01c0d8cc 801cac74 81d0d001 00000000 00008001 81c92ae0
Call Trace:
[<8020ea10>] squashfs_kill_sb+0x14/0x38
[<801b350c>] deactivate_locked_super+0xb4/0xfc
[<801b3c80>] mount_nodev+0x6c/0xbc
[<801b4918>] mount_fs+0x20/0xe8
[<801cba44>] vfs_kern_mount+0x5c/0xd4
[<801cbd3c>] do_kern_mount+0x44/0xf8
[<801cd88c>] do_mount+0x5c4/0x678
[<801cd9e4>] sys_mount+0x94/0xe4
[<803f2cbc>] mount_block_root+0x12c/0x2d0
[<803f309c>] prepare_namespace+0x1c8/0x20c
[<803f2a68>] kernel_init+0x114/0x11c
[<80107150>] kernel_thread_helper+0x10/0x18
Code: afb00010 8c820194 00808021 <0c06ca3b> 8c440000 0c06cbe0 02002021 8fbf0014 8e040194
—[ end trace 782ff75f27409cd9 ]—
Kernel panic - not syncing: Attempted to kill init!
Hi, you have old routerboot. Before upgrade you must have routerboot 2.18. Now reinstal router with netinstall http://wiki.mikrotik.com/wiki/Manual:Netinstall
then upgrade routerboot to 2.18 and install 6.1 http://download2.mikrotik.com/routeros/6.1/routeros-mipsle-6.1.npk
See comment on download page:
Before upgrading RouterBOARD 1xx or 5xx series devices (MIPS-LE) to version >=5.17, please upgrade your RouterBOOT firmware by uploading one of the following files to your corresponding device, and issuing command “/system routerboard upgrade”. Download for: [RB1xx]; [RB5xx]
I just got a few RB133c3s that I am trying to reset to defaults.
  • They boot fine, but I don’t know the password to log in.
  • I can’t figure out how to get the reset button/jumper to reset the ROS configuration.
  • When using netinstall/bootp, they give a one-line “kernel panic” message.
As a last resort, I want to try upgrading the boot loader via xmodem–but although the available documentation says to download the routerboot image from routerboard.com, I can’t find a link to it anywhere. Can someone please send me a current link to download routerboot 2.18 for mipsle? Or tell me exactly how to use the button/jumper to reset the ROS configuration?
