Kernel panic/error ubifs CCR1016-12G r2 BBAA0B09ADA4/012/r2
This unit do not work. I have some “r1” that work nicely, this “r2” do not work.
Netinstalled without keep config with proper version, with 6.44.6 - 6.45.9 - 6.46.6 - 6.47
also try format nand from bios
updated bios for every version, the problem still present
Just netinstalled:
[admin@MikroTik] > export file=x
file operation error
winbox work but “file” do not work, i can not delete file, no copy, when reboot I lost all config, but I can still upgrade or downgrade boot or routeros.
RMA or driver kernel error?
Dump from console port:
CPU frequency: 1200 MHz
  Memory size: 2048 MiB
    NAND size: 512 MiB
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Could not mount ubifs filesystem: Invalid argument
opendir: No such file or directory
Kernel panic - not syncing: Attempted to kill init!
Starting stack dump of tid 1, pid 1 (init) on cpu 3 at cycle 19634195000
  frame 0: 0xfffffff700520050 dump_stack+0x0/0x20 (sp 0xfffffe403feffc08)
  frame 1: 0xfffffff700518fe8 panic+0x168/0x398 (sp 0xfffffe403feffc08)
  frame 2: 0xfffffff700053a78 do_exit+0x1c8/0xd48 (sp 0xfffffe403feffcb0)
  frame 3: 0xfffffff700054740 do_group_exit+0xf0/0x1e8 (sp 0xfffffe403feffd78)
  frame 4: 0xfffffff700054858 __wake_up_parent+0x0/0x18 (sp 0xfffffe403feffdb0)
  frame 5: 0xfffffff700520d98 handle_syscall+0x210/0x2d0 (sp 0xfffffe403feffdc0)
  <syscall while in user mode>
  frame 6: 0x901a8 0x901a8 (sp 0x7fa0f968)
Stack dump complete
Rebooting in 1 seconds..Resetting chip and restarting.
If the device is still with warrantee, change it for a new one.
Regards.
