Key export + Open VPN
In a CHR I export a certificate + key in PEM format, I give a password to encrypt the key, and I use this certificate with Openvpn client (Windows, 64bit, latest version: 2.4.7)
With CHR 6.45 version everything goes well. With the 6.45.1 and 6.45.2 versions the Openvpn drop an Openssl error:
“OpenSSL: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch” and it cannot read the key.
I see in the changelog that in the 6.45.1 version there was upgrade in the PKI topic.
So, is it a MikroTik or OpenVpn bug or something incompatibility?
