flynno
December 6, 2018, 9:14pm
1
Hey guys,
i require help removing a device using the Pear2 api
Two lines of code below that I am using to remove the device.
I have a form created to get the name of the device to be removed that passes the variable $device_remove
$addRequest = new RouterOS\Request(‘/ip kid-control device remove’);
$addRequest->setArgument(‘name’, $_POST[‘device_remove’]);
Thanks in advance
flynno
December 7, 2018, 3:57pm
2
$util->setMenu(‘/ip/kid-control/device’);
$util->remove(($_POST[‘device_remove’]));
Solved using util
flynno
December 8, 2018, 3:27pm
3
Anyone have the correct API to update a current profile to another profile without deleting the existing one.
Here is what I have so far;
<?php
// Receiving variables from filled form
@$device_name = addslashes($_POST['device_name']);
@$profile_select = addslashes($_POST['profile_select']);
use PEAR2\Net\RouterOS;
include_once 'PEAR2/Autoload.php';
try {
$client = new RouterOS\Client($_SESSION['user']['remoteadd'],$_SESSION['user']['remoteuser'],$_SESSION['user']['remotepass']);
} catch (Exception $e) {
die('
Woops!! Please Forward Ports 8728 and 8291 to Router IP Address to Avoid this Warning
$addRequest = new RouterOS\Request('/ip kid-control device');
$addRequest->setArgument('name', $_POST['device_name']);
$addRequest->setArgument('user', $_POST['profile_select']);
if ($client->sendSync($addRequest)->getType() !== RouterOS\Response::TYPE_FINAL) {
die("Device already active, please remove device and set new profile");
header('Location: index.php');
exit();
I want to be able to update an existing profile in kid-control without having to delete the profile to add a new one
flynno
December 9, 2018, 9:30pm
4
Solution
@$device_name = addslashes($_POST[‘device_name’]);
@$profile_select = addslashes($_POST[‘profile_select’]);
require_once ‘PEAR2/Autoload.php’;
try {
$util = new RouterOS\Util(
$client = new RouterOS\Client($_SESSION[‘user’][‘remoteadd’],$_SESSION[‘user’][‘remoteuser’],$_SESSION[‘user’][‘remotepass’])
die(‘
$util->set(
$_POST[‘device_name’],
array(
‘user’ => $_POST[‘profile_select’]
header(‘Location: index.php’);
exit();
