kill connection from terminal window
Is there any way to kill connection from terminal with some command.
I can’t open winbox: ip/firewall/connection, CPU go to 100% :frowning:
only solutios is to kill conn with some command from telnet or terminal
I need to kill all conn with src.adr:x.x.x.x and dst.adr:x.x.x.x
I can’t used remove 1, remove 2 … because we have over 3000-4000 connection, I can not list, procesor go to 100%,
I this server will stop respond
is there way to do this with , remove src-addres … ?
