KILLED MY GROOVE LAN PORT - HELP
Recently purchased a Groove A-52HPn to use in the Bahamas with Bahama Telco Wi-Fi. Somehow in messing with the Webfig I turned OFF the LAN port and Wi-Fi. The radio part is still receiving my AP signal as shown on the signal strength LEDs.
Here is what I see: When powered it appears to go into BOOT, the far right and Wi-Fi LEDs are flashing. My network screen on my PC shows something is connected to the LAN port. At the end on the BOOT, the far right and Wi-Fi LEDs go out. My PC no longer shows anything is connected to the LAN port. On the Groove, the AP signal bar show a strong signal (4 bars, from my cellphone).
I’ve tried over and over to reset, tried holding the reset during a power-up until all LEDs go out. Tried Winbox First_Start, regular Winbox, Netinstall (but really don’t have it se tup right), nothing.
What can I do to restore the LAN? Guess I should say, I’m a beginner with a little knowledge. I did get the AP part working.
Any assistance would be appreciated.
Have you folow the correct procedure?
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
