Kindly Suguest me
Hellos.
I m getting problem in Load Blancing with pcc and 7 DSL lines.
i Have 7 ADSL lines and using Mikrotik pcc method for load blancing. But when i check only 6 Lines getting trafice for load blancing while the last one is not giving bandwidth. even i try to disable all ADSL and only enabled 7th DSL ethernet. but still last adsl is not giving me bandwidth.
i m using pcc method with dialing DSL username and password
i also check my lan card and modem etc by changing 6th ppoe to ethernet 7.
my question is that pcc method is only for 2, 4 and 6 ADSL?
or it can also be used for more 5 , 7 and 9 ADSL?
PCC will work with any number of “ADSL”.
Assuming that you have tested the 7th line without PCC (i.e. you confirm that the dialer is correct and traffic is NATting to the internet just fine), please paste the output of the following three commands (executed separately):
/ip firewall mangle export compact
/ip firewall nat export compact
/ip route export compact
hmmmmmmmmmmmmmmmmmmmmmmm
Bump…
waiting for reply
