It worked to a point, but it kept popping up a debugger window on me. It did actually scan the network, but I just have to keep telling it not to debug.
It’s very nice, but took several attempts till it ran to completion on a W2k machine in the office - several attempts made it crash i.e. program terminated.
So a couple of bug fixes and “yet another useful tool from MT” - well done.
Isn’t this about the same as the dude discovery (with pdf output)? Only it’s limited to your local network only…any chance on adding the capability to add networks?
You did see the smiley at the end of my post, yes?
I think most people here DO realize that they get a great piece of software for FREE (talking of Dude) from MikroTik. And most of those do really appreciate this…
yes, that's sofware is nice and magic, but after use it my pc can't connect to gateway...
now for temporary when i need it, i will use it
so sorry from and to router we have rules policy
nest - the tool scans the network and all the ports, maybe your software didn’t like this behavior, although this is exactly what Dude and KTN are made to do. Before using them, I suggest to turn off any firewalls or network security systems. You can send them the file if you like.
I have received a reply from Sophos Technical Support acknowledging that the file kiss.exe is not malware and has been incorrectly identified by their anti-virus engine. I.e. it is a false positive. They have released a new IDE file to remove this false positive. I have this latest update from them, and I m now able to report that kiss.exe is NOT reported as a Malware.
So… I am now able to test this program without Sophos stopping me.
I think what people are referring to can be disabled by turning off all script debugging in Internet Explorer. I have Microsoft Visual Studio 6 installed and that kept trying to debug KTN - so I assume that there is a bug or two in the program.
