KNOT - cant beck to default configuration
I can’t reset the settings to factory defaults in MikroTik Knot.
I tried:
  1. Turn off the power, press the reset button, turn on the power, wait for 10 seconds - it doesn’t help, even with variations (2 seconds, 20 seconds, one minute);
  2. Turn off the power, turn on the power, press reset for 2 seconds - it didn’t help;
  3. I disassembled the Knot - I didn’t find a jumper like in other devices for resetting.
How to reset the Knot to factory settings?
hola ya pudiste solucionarlo me sucede igual
Hola, bienvenido al foro, para que tengas una mejor comunicación e interacción lo mas recomendable es que utilices el idioma ingles
Hello, welcome to the forum, so that you have better communication and interaction, it is most recommended that you use the English language
You might just use netinstall to reset it to defaults.
But it is critical you do not press reset button MORE than 10 seconds - it should be around 6-7 seconds from power on & normally some light goes from solid to flashing, at which point you release the reset button.
While the button reset should work, but some of the KNOT came with V6 and if you install V7 but didn’t upgrade the firmware…or other such combos, possible the power-on-while-pressing-reset-5ish-seconds method to reset might not work. Why netinstall (ideally from a Linux box) be more guaranteed to work (although more work to setup).
