I am trying to connect a KNOT Embedded LTE4 to a SparkFun RTK Facet (a GNSS device) using RouterOS BLE central mode. Running the BLE connection command consistently causes a RouterOS failure and generates autosupout.rif.
Hardware and software:
- MikroTik KNOT Embedded LTE4, ARM, 256 MB RAM
- SparkFun RTK Facet
- Facet firmware v4.4
- ZED-F9P firmware HPG 1.50
- Facet uses the Nordic UART Service:
- Service:
6e400001-b5a3-f393-e0a9-e50e24dcca9e - RX:
6e400002-b5a3-f393-e0a9-e50e24dcca9e, Write - TX:
6e400003-b5a3-f393-e0a9-e50e24dcca9e, Notify and Read
- Service:
I have reproduced the problem on:
- RouterOS 7.24.5 stable
- RouterOS 7.26beta5
The Facet is discovered normally:
/iot bluetooth peripheral-devices print detail where address="<FACET-MAC>"
Example result:
address-type=public
address=<FACET-MAC>
rssi=-72
last-data="02010611079ECADC240EE5A9E093F3A3B50100406E051212004000"
The advertisement contains the Nordic UART Service UUID.
The scanner is active:
/iot bluetooth scanners set [find device=bt1] \
disabled=no type=active filter-duplicates=keep-newest
The failure is triggered by:
/iot bluetooth connections connect pdev=<FACET-MAC>
The KNOT becomes unresponsive, the SSH session goes down and I have to wait a while before I can reconnect. Shortly after reconnecting, RouterOS reports:
system,error,critical Automatic supout.rif file generated due to service malfunction
In an earlier reproduction, the log also reported:
router was rebooted without proper shutdown, probably kernel failure
kernel failure in previous boot
The corresponding RIF contains had panic. It reports Bluetooth controller firmware 2.0.0.gf6614dc292, built on 2026-01-13.
To eliminate configuration and data-rate issues, I also tested after:
- Resetting the KNOT to factory defaults.
- Enabling only the Bluetooth scanner.
- Configuring the Facet with all GNSS/NMEA output rates set to zero.
- Attempting exactly one connection.
The clean factory-default test generated another autosupout.rif.
The Facet works without issue with Android nRF Connect. The phone can connect, discover the Nordic UART Service, enable TX notifications, exchange NMEA data, and negotiate ATT MTU 517. I have also previously used this KNOT for bidirectional BLE communication with an nRF Connect server running on a phone, so BLE central/GATT operation has worked with another peripheral.
Questions:
- Is this a known KNOT BLE central/GATT issue?
- Does
/iot bluetooth connections connectautomatically perform an MTU exchange, and can its requested MTU be limited? - Is there any Bluetooth or HCI debug logging available beyond the generated RIF?
- Is there a RouterOS version or workaround that should be tested?
- Where should I submit the RIF files for private analysis?
I have RIF files from both the original and factory-reset reproductions and can send them privately to MikroTik support.
Any advice is very welcome!
