KNOT modem port / CAT-M/NB
Hi there,
Product : KNOT RB924i-2nD-BT5&BG77
Issue : cannot configure BG77 modem.
In Ports you can only choose Modbus RS485 serial and USB2 (GPS)
So where is the BG77 port?
/port print :
 #   DEVICE NAME                     CHANNELS USED-BY                   BAUD-RATE
 0          modbus                          1                           9600
 1          usb2                            4                           9600
        routerboard: yes
        board-name: KNOT
             model: RB924i-2nD-BT5&BG77
     serial-number: E0FD0ECF.....
     firmware-type: qca9531L
  factory-firmware: 6.48.2
  current-firmware: 6.48.3
  upgrade-firmware: 6.48.3
Ok, update/closed:
It is indeed USB2 and not “Modem” as in previous versions.
Furthermore you should have a SIM inserted.
After inserting SIM you will see it is used by ppp-out1 :
Flags: I - inactive
 0          modbus                                     1                                      9600
 1          usb2                                       4 PPP <ppp-out1>                       9600
