KNOT - quality / strength of LTE connection
Is there a particular method for being able to determine the signal strength / quality of connection, or is the only means by disabling the interface and then running a status?
Conceptually, I’d like to find a way for remotely being able to see the signal strength - in order to determine if the device has a good signal where it is located.
