KVM and "unsupported pcu"
Hello.
I have a little problem.
I want to install a small Linux distributions.
In this distribution I want to run radius server, web server and many others.
But I can not install any version of Linux, all the time says “unsupported PCU
Can someone tell me what is wrong?
If you need more information, please ask.
Waiting for your help
You need processor with hardware virtualization support, eg. VT-X, AMD-V.
that is, I can not use KVM on this machine?
I can only metarouter and OpenWRT, exactly?
Where can I find a list of processors that support virtualization?
http://en.m.wikipedia.org/wiki/Intel_VT-x
there is a yet unresolved problem that somehow user is not able to run KVM on machine that supports virtualization.
But first things first - check if BIOS is as fresh as you can get, check if all the settings about virtualization is enabled in there (the BIOS) if using RC7 and not encountering the problem i described, KVM guests should work.
I have the latest Bios.
I checked, there is nothing in the BIOS on virtualization.
All the settings seem to be good.
I do not know why this happens.
Just want to install a Radius server. To avoid having to put another computer.
