KVM Broken RouterOS 5.9 ?
Hi
Is any else have a problem with RouterOS v5.9.
I try and create a routeros image and the router always comes back and says failed to copy to router
[admin@MikroTik] > /kvm make-routeros-image file-name=“RouterOS.img” file-size=1000
failed to copy files to image
I am running this on an X86 PC
somehow it worked on my box, need more details. What packages installed, how much free resources, what disk, where connected, is virtualization supported on the host.
Hi.
When I tried before I hadn’t applied the License key. Once I applied it I was able to create the image. I don’t know if its related or just coincidence.
its working now. There was more than enough HDD space, and resources where fine (this is brand new and almost no config on atm)
that is license limitation - you cannot create virtual devices you do not have the license key applied.
it seems i’m still having this issue.
[admin@MikroTik] > /kvm make-routeros-image file-size=10000 file-name=linux.image
[admin@MikroTik] > /kvm make-routeros-image file-size=32 file-name=linux.image
[admin@MikroTik] > /kvm make-routeros-image file-size=42 file-name=linux.image
[admin@MikroTik] > /kvm make-routeros-image file-size=40 file-name=linux.image
[admin@MikroTik] > /kvm make-routeros-image file-size=50 file-name=linux.image
[admin@MikroTik] > /kvm make-routeros-image file-size=34 file-name=linux.image
[admin@MikroTik] > /kvm make-routeros-image file-size=340 file-name=linux.image
[admin@MikroTik] > /system resource print
uptime: 16h48m32s
version: 5.9
free-memory: 1889208KiB
total-memory: 1943364KiB
cpu: Intel(R)
cpu-count: 2
cpu-frequency: 2793MHz
cpu-load: 0%
free-hdd-space: 306633628KiB
total-hdd-space: 307647764KiB
write-sect-since-reboot: 88538184
write-sect-total: 88538184
architecture-name: x86
board-name: x86
platform: MikroTik
What can i do to fix this? still running v5.9
