L 07 07 07 07 ....
On first boot up after CD install at 7F all I see is
L 07 07 07 07 07 07 07 07 07 07 07…
It goes on for 10 or 12 lines adding another “07” every minute.
I assume this is some sort of hardware compatibility problem. I was expecting the first time login instead.
The system is an IBM PC model 300PL with 256MB RAM / 40GB HD / and a SIIG PCI/PCMCIA bridge in it.
Anyone with insight to what the error means, I appeciate the info.
-T Heckler
whats ur harddisk?? type most cases from harddisk not compatible
Put the hard disk on ide0 and reinstall it.
The hard drive is a salve behind the CDROM. Will that not work properly. The initial install runs fine. It is a Western Digital WD400BB Enhanced IDE drive.
I switched the HD to IDE0, and it works fine. Thanks for the help!
