L009 driven by capsman on Hex doses not work
Hello there,
i am new to mikrotik and having setup of couple CAP lites connected to hEX PoE and it works sort of well.
hex role is bridge, capsman and POE
then i have a L009UiGS-2HaxD eth3 connected to hex eth1 and I am trying to get the l009 wifi1 to be managed by capsman
plea help me as i cant see the radio of l007 in the capsman in hex
configs attached
thanks in advance
hex.txt.rsc (2.18 KB)
l009.txt.rsc (8.38 KB)
You are mixing two radio versions so two different parts of menu to be used.
Hex should be on at least ros 7.13.
Then use wifi menu for config of L009.
Wireless for cap lite.
Thanks for the verison difference, i thought I was on the latest then I noticed there is a upgrade option in the package menu
Now Have the 7.16 on both the devices, unfortunately cant see the radio of l009 in any of the menu of the hex which should be the capsman" for all wifi.
please can you advise?
Without seeing config of both devices, that might be problematic for anyone.
Terminal
export file=anynameyouwish
Move file to PC
Edit file and obfuscate any private info (serial, WANip, passwds, …)
Then post back between [__code] [/__code] quotes for easier readability.
Here is the L009
# 2024-10-29 15:43:52 by RouterOS 7.16.1
# software id = YIXI-4KKY
# model = L009UiGS-2HaxD
add admin-mac=78:9A:18:FC:88:71 auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
set [ find default-name=sfp1 ] disabled=yes
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.mode=ap .ssid=green2 disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
/interface vlan
add interface=bridge name=vlan10-standard vlan-id=10
add interface=bridge name=vlan20-guest vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool-mgmt ranges=10.10.10.10-10.10.10.254
add name=pool-standard ranges=10.10.30.10-10.10.30.254
add name=pool-guest ranges=10.10.20.10-10.10.20.254
add address-pool=pool-mgmt interface=bridge name=dhcp-mgmgt
add address-pool=pool-standard interface=vlan10-standard name=dhcp-standard
add address-pool=pool-guest interface=vlan20-guest name=dhcp-guest
/port
set 0 name=serial0
/routing table
add disabled=no fib name=inetek
add disabled=no fib name=o2
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=wifi1
/interface bridge vlan
add bridge=bridge tagged=ether3 vlan-ids=10
add bridge=bridge tagged=ether3 vlan-ids=20
add interface=sfp1 list=WAN
/interface wifi cap
set caps-man-addresses=10.10.10.250 caps-man-names=capp discovery-interfaces=\
    bridge enabled=yes
add address=10.10.10.1/24 comment=defconf interface=bridge network=10.10.10.0
add address=10.10.20.1/24 interface=vlan20-guest network=10.10.20.0
add address=10.10.30.1/24 interface=vlan10-standard network=10.10.30.0
add address=10.0.97.198/27 interface=ether1 network=10.0.97.192
/ip dhcp-client
# Interface not active
add comment=defconf interface=sfp1
/ip dhcp-server lease
add address=10.10.10.253 client-id=1:78:9a:18:fb:87:70 mac-address=\
    78:9A:18:FB:87:70 server=dhcp-mgmgt
add address=10.10.10.250 client-id=1:78:9a:18:ac:10:28 mac-address=\
    78:9A:18:AC:10:28 server=dhcp-mgmgt
add address=10.10.10.251 client-id=1:d4:1:c3:d6:5:55 mac-address=\
    D4:01:C3:D6:05:55 server=dhcp-mgmgt
add address=10.10.10.252 client-id=1:78:9a:18:fb:85:ed mac-address=\
    78:9A:18:FB:85:ED server=dhcp-mgmgt
add address=10.10.10.179 client-id=1:9c:93:4e:40:ce:41 mac-address=\
    9C:93:4E:40:CE:41 server=dhcp-mgmgt
add address=10.10.10.10 client-id=1:8c:1d:96:c6:4b:75 mac-address=\
    8C:1D:96:C6:4B:75 server=dhcp-mgmgt
add address=10.10.10.7 client-id=\
    ff:56:50:4d:98:0:2:0:0:ab:11:4:6b:fe:e4:56:6b:a8:6e mac-address=\
    40:8D:5C:A4:56:6A server=dhcp-mgmgt
add address=10.10.10.0/24 comment=defconf dns-server=10.10.10.1 domain=local \
    gateway=10.10.10.1
add address=10.10.20.0/24 dns-server=10.10.20.1 domain=local gateway=\
    10.10.20.1
add address=10.10.30.0/24 dns-server=10.10.30.1 domain=guest gateway=\
    10.10.30.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=10.10.40.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=input dst-port=5246,5247 protocol=udp
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Prague
/system identity
set name=RouteR
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
here for the hex
# 2024-10-29 15:44:34 by RouterOS 7.16.1
# software id = U0W4-NS6J
# model = RB750UPr2
add ingress-filtering=no name=bridge-vlans port-cost-mode=short \
    vlan-filtering=yes
/interface vlan
add interface=bridge-vlans name=vlan10-standard vlan-id=10
add interface=bridge-vlans name=vlan20-guest vlan-id=20
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=sec-guest
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=\
    sec-standard
/caps-man configuration
add datapath.bridge=bridge-vlans .vlan-id=10 .vlan-mode=use-tag name=\
    cfg-standard-wifi security=sec-standard ssid=green2
add datapath.bridge=bridge-vlans .vlan-id=20 .vlan-mode=use-tag name=\
    cfg-guest-wifi security=sec-guest ssid=green2hosty
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] supplicant-identity=MiroTik
/ip smb users
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg-standard-wifi \
    slave-configurations=cfg-guest-wifi
add bridge=bridge-vlans ingress-filtering=no interface=ether1 \
    internal-path-cost=10 path-cost=10
add bridge=bridge-vlans ingress-filtering=no interface=ether2 \
add bridge=bridge-vlans ingress-filtering=no interface=ether3 \
add bridge=bridge-vlans ingress-filtering=no interface=ether4 \
add bridge=bridge-vlans ingress-filtering=no interface=ether5 \
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add bridge=bridge-vlans tagged=ether1 vlan-ids=10
add bridge=bridge-vlans tagged=ether1 vlan-ids=20
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/ip dhcp-client
/ip dhcp-relay
add dhcp-server=10.10.30.1 disabled=no interface=vlan10-standard name=relay10
add dhcp-server=10.10.20.1 disabled=no interface=vlan20-guest name=relay20
add action=drop chain=forward disabled=yes dst-address=10.10.30.0/24 \
    src-address=10.10.20.0/24
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system identity
set name=PowerBridge
/system note
On Hex side nothing is setup for capsman for AX devices ?
You’re missing things like:
/interface wifi channel
<channel definitions>
/interface wifi security
<security deinitions>
/interface wifi capsman
set enabled=yes interfaces=<whatever>
/interface wifi configuration
<Configuration settings>
/interface wifi datapath
<Datapath settings>
/interface wifi provisioning
<provisioning>
Side remark:
if L009 is the only AX-radio in your network, why bother with capsman for it ?
Set it up standalone and look into it again when you have multiple AX devices in your setup.
