The L009 comes in two versions one (IMHO right) without WiFi/Radio and one (IMHO wrong) with (2.4GHz radio).
For both it is highlighted that 4 of them can be mounted in a 1U space of a rack, for the former it is fine, for the second you will need to use external antennas and in any case it makes no sense to have four radios/eight antennas in a same spot.
What one could do at most in a rack is to have 1 L009 with the radio and 3 without, but the “real” use of a L009 with radio is a self-standing device (and in that use it could be useful to have the 5GHz radio) but there are already more suitable Mikrotik devices for that use (Ax2, Ax3) the only drawback being less ports, easily solved with an added small switch.
In any case, particularly with 5GHz, you need to distribute as much as possible the coverage with more access points, so having the “main” router being also a Wi-Fi device is becoming (IMHO) less common/useful (unless it is a small house/office that can be all covered by the single router Wi-Fi from its position, which often depends on where the ISP cable arrives), it seems to me increasingly common that the router is placed somewhere in a corner and Wi-Fi coverage is obtained through access points even in relatively small homes/offices.
The RB009 is a much more powerful device that comes in the same form factor of the L009 (4 can be mounted in i1U) in two models, both without radios, one with and one without PoE out.
The fact both versions exist of L009, makes it the user responsibility to decide if they want to use it or not.
You don’t have to. You have the choice.
MT definitely had it’s reasons to release it with wifi, otherwise they would not have done it.
Similar issue with AX Lite, only 2.4Ghz AX wifi. AX Lite LTE, only 2.4GHz AX wifi.
The Tik device I use in the most flexible way is mAP. Only 2 Fast ethernet ports (not even Gigabit), only legacy 2.4GHz wifi. GREAT device for what it can do.
There are plenty of cases where only 2.4GHz is more then enough for what is needed.
Actually there are 2 form factors for RB5009 (and L009 took its case from RB5009, that latter one was released first long before there was even mentioning of L009).
There is also an outdoor version of RB5009, completely different package.
L009UiGS-2HaxD-IN
L009 is more than just a router. This product line is up to 4 times faster than RB2011, it has a modern ARM CPU with container support, an innovative enclosure that > allows > mounting up to four routers in a single 1U space> , more RAM, PoE, and 2.5G SFP support. This version comes with 2.4 GHz ax dual-chain wireless.
The earlier reply from MikroTik has been that the L009 is intended solely as the replacement for their most successful device ever, the RB2011.
Apparently there are still people buying that, and they wanted to introduce a replacement device with similar price and features.
When you require 5GHz, don’t buy the L009 but select another device.
… makes no sense. It’s silly to not have put 5ghz in
I’m pretty sure people aren’t buying the 2011 specifically because it DOESNT have 5ghz in it
Should the L009 have also had half its ports 100mbit just because its a 2011 replacement?
If its a true replacement why only 8 ports and not 10?
Times change, products improve and get better - or at least they should
Whilst its true that plenty of devices are still 2.4ghz and your weather monitor or cheap TV might do just fine, typically it’s a mixed environment and not having 5ghz just gimps the laptop/phones that would substantially benefit from it (and further takes away from the 2.4ghz airspace, slowing down the slow devices even further)
Sure, but there’s a big difference between not trying to satisfy everybody, and releasing total gimp…
.. Like should any device now ever be released with 10mbit ethernet ports? No absolutely not
2.4ghz is not quite on that level, and it has some justification in niche situations like low powered devices (such as a mAP which probably wouldn’t get enough power from a USB port to power 2x radio chips properly) and real cheap nasty bottom end entry products. But are either of those really the L009? it’s not that cheap nor some niche product. I’d be willing to bet if they released a L009+ or some such which had both 2.4 and 5ghz for $10-15 more, they’d sell almost none of the 2.4ghz only models
There is 4011iGS+5HacQ2HnD-IN if you need both freq …
You say 10-15$ more thay say better chassis means less WiFi …
4011 has WiFi 5009 has more power
There is S53UG+M-5HaxD2HaxD-TC&RG502Q-EA if you want LTE + WiFi
IMHO really it’s hard to make every possible configuration suitable for everyone and MT has sales reports and knows what is popular and portfolio is more (hope) or less (hope not) based on that.
No, they are buying it because it costs ~$120 and has a lot of features.
Look, I am not on the MikroTik product specification board!
Apparently there is demand for such a product. I would not buy it either, or at most buy the version without WiFi for an installation where WiFi is not required or handled by other equipment.
There are always customers who first look at the last line of the product spec and make their decision based on that, rather than on many other factors.
Whatever you do, do not buy that one!
When you install the modern WiFi driver it will work ONLY on 5 GHz and 2 GHz will become inoperative.
Also, it has no USB port so no way to expand storage. It has lots of RAM but no way to do anything with it (like running containers).
Hopefully we will see a similar “5011” device that has everything the 4011 has, but:
supported 2 GHz WiFi controller
USB port
2.5Gbit/s on at least the first 5 ports
Of course that would cost way more than the L009 so that one still has a valid space on the market.
L009 is for a very specific use case. We have a very large number of customers that keep buying RB2011 as they don’t need/want 5GHz, but do need those few extra ports. L009 is a drop in replacement for those people. I get that other people (like in this thread) would like a similar device that looks like that and does something else, yes.
It is very simple. Everywhere where is 5GHz there are only 2dBi 2,4GHz antennas. L009 has a 4dBi 2,4GHz antennas, meaning you can have a signal in the whole house and garden with a single device. If you do not need high-speed wi-fi (e.g. for VR headset)
