My L009UiGS-2HaxD power off when plugin ether1 cable, inmediatly, if I unplug the cable, the router power on again.
I hava other Mikrotik HAP AC, and I made some tests (test made with HAP AC without power source, no power cable or other devices connected):
- If I plug a cable from ether1 (Port 1) from L009 to Port 5 of HAP AC (POE out port) nothing happens (L009) keeps on.
- Pluggin the cable from L009 ether1 to HAP AC’s port 1, powers on the HAP AC, boots a cable link lights on both routers, seems like POE out is enabled on port 1 of L009 How is this possible?
- IPlugin the cable from L009 ether 1 to HAPC Ac’s port 2, port 3 or port 4, makes L009 to power off inmediatly. HAP AC remains off (No power source). As soon as I disconnect the cable on either side, L009 power on.
Please anyone can give an advice or any help. Is this behavior normal? Could be a hardware issue?
L009 is brand new.
I made the tests with different cables and other routers that I have, the results are the same as I posted above. The output POE port (port 8) work as expected.
Tested firmwares with same result:
- 7.20.2 (stable)
- 7.16.2
- 7.12 (factory firmware)
