L009UiGS-RM - No internet
Hi
UPDATE: I just needed to restart the cable modem so it gives out the IP, silly me.
I’ve used the default configuration, and I can’t seem to see what’s wrong, I have put the config below, i’ve got WAN connected to ether1 and my pc on ether2. The DHCP client just gets stuck on ‘searching’
Any help would be appreciated, thanks a lot!
# 1970-01-02 00:31:09 by RouterOS 7.15.3
# software id = IMX8-PMTJ
# model = L009UiGS
# serial number = HFJ094EPPC3
add admin-mac=78:9A:18:F3:45:4E auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=sfp1 internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
/ip settings
set max-neighbor-entries=14336
/ipv6 settings
set max-neighbor-entries=7168
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
