L2 MTU on RouterOs Cloud
Dear all,
I installed RotuerOS Cloud Hosted on OpenStack.
I think to have some problem with interfaces. L2 MTU value reported on ethernet interfaces is egual zero while MTU value is 1500. The Auto Negotiation fails and rate reported is unknown. Also if I disable autonegotiation and set manual velocity the rate status is always unknown.
Can you help me?
