I have RB600 with 3 ethernet in bridge mode. Eth 1 is uplink. I need to make this:
Eth 2 is high speed wirelles link with high latency more tha 70 ms.I need use ethernet 3 just for icmp packets for reduce Pings through this line. Is it possible? I dont know how to make it does somebody help me? ROS v 3.0
I need transparent link. without routing.
I need reduce ping the wimax radio.. is is around 70 ms. I want to connect simple 5GHz radio link to ethernet 3 just for icmp packets. Is it possible? Wimax radiu is connected to eth 2 .
It is better to use v3 for correct DSCP values.
v3 provides full support for DSCP values.
Note, in fact min-delay does not mean, that traffic will go trough the routers with minimal delay.
It is just additional setting for more advanced QoS. Only mangle rule with DSCP=1 (that could be abbreviated as min-delay) will not make any influence to your QoS. But you will get advantage, when you will use queues based on DSCP packet-marks.
