L2 Tunnel for 1600 byte packets
Hi
I need to build a fully transparent layer 2 tunnel (VLAN, CDP, DSCP, etc.) that can handle 1600 byte packets. The problem is that a part of the transit network is only able to transmit 1504 bytes per packet.
How can this be done?
Btw. I know that the PPS will be double of the original data but it’s a low bandwidth link, so I can live with that.
Thanks for your help!
  • Mat
