L2 tunnel trunk
Hei
I need to set up a tunnel between A ↔ B
The tunnel needs to be able to trensport a VLAN trunk.
Using RB493 AH in each end.
Whay is my best option?
PPPtPv3 or EOIP??
I do not need encryption on this.
Just best performance and stability..
http://wiki.mikrotik.com/wiki/Manual:Interface/EoIP
http://wiki.mikrotik.com/wiki/Manual:Interface/Gre
http://wiki.mikrotik.com/wiki/Manual:Interface/IPIP
Thank you for helping out.
But witch is the best choice…
Remember I also need to pass a VLAN trunk.
I have set up a EOIP tunnel in the lab to test it out.
But I was dissapointed with the performance.
I got 10Mbps one way, and 25Mbps the other way.
This was strange, as the RBs was directly connected to each other.
Speed test was run on two PCs connected over the tunnel.
Spees test is ok using a switch between the PCs (96/96Mbps).
