L23UGSR - Permanently disable wifi?
Using two L23UGSR to bridge components, would like to turn wifi off permanently, as there will be no antennas connected, just fiber.
Disable WiFi interfaces or just uninstall wireless/WiFi package what would "kill" interfaces as there would be no drivers to serve them.
Neither L23 lists any packages at all, I did reset the configuration on both.
Now just some weirdness, the SFP port on one went 'inactive' and had to remove/reseat the SFP twice, but now they're talking
WiFi interfaces are visible? If you do not see them, then WiFi is off.
Maybe you have to manualy add proper wireless package first to be able use them. You can check it just for test. I'm not aware of default factory package set used/installed.
