I want to use mt as a l2tp client to connect to Juniper ssg 520,but something is wrong:
MT(192.168.67.237/23) ------> Juniper(192.168.67.236/23)
L2TP Server:
Juniper ssg 520:
configuration:
set interface “ethernet0/0” zone “Trust”
set interface “ethernet0/2” zone “Untrust”
set interface ethernet0/0 ip 192.168.200.1/24
set interface ethernet0/2 ip 192.168.67.236/23
set address “Trust” “192.168.66.0/24” 192.168.66.0 255.255.255.0
set route 0.0.0.0/0 interface ethernet0/2 gateway 192.168.66.1
set ippool “testpool” 172.16.55.3 172.16.55.6
set user “test” uid 1
set user “test” type l2tp
set user “test” remote ippool “testpool”
set user “test” “enable”
set user-group “testg” id 3
set user-group “testg” user “test”
set l2tp default dns1 192.168.66.1
set l2tp default ppp-auth chap
set l2tp “testtunnel” id 2 outgoing-interface ethernet0/2 keepalive 60
set l2tp “testtunnel” remote-setting ippool “testpool”
set policy id 1 name “test2” from “Untrust” to “Trust” “Dial-Up VPN” “Any” “ANY” nat src tunnel l2tp “testtunnel” log
L2tp Client:
MikroTik Ros v5.6
[admin@MikroTik] /interface> l2tp-client print
0 X name=“test1” max-mtu=1460 max-mru=1460 mrru=disabled connect-to=192.168.67.236 user=“test” password=“test” profile=default-encryption add-default-route=no dial-on-demand=no
allow=pap,chap,mschap1,mschap2
MT Logs:
09:12:53 l2tp,ppp,info test1: initializing…
09:12:53 l2tp,ppp,info test1: dialing…
09:13:17 l2tp,ppp,info test1: terminating… - session closed
09:13:17 l2tp,ppp,info test1: disconnected
09:13:17 l2tp,ppp,info test1: initializing…
09:13:17 l2tp,ppp,info test1: dialing…
09:13:17 l2tp,ppp,info test1: terminating… - old tunnel is not closed yet
09:13:31 system,info,account user admin logged in via local
09:13:40 l2tp,ppp,info test1: terminating…
when mt(l2tp client) connect to juniper,after serval seconds,Error:Router has been disconnected! and i can’t connect to mt port 8291.
