I’ve been using l2tp client connections on hEx routers without problem.
I recently tried the hAP modules and got stuck : l2tp client never connects to my server, 1.2.3.4.5 in my log below.
So what could be wrong ? I’m using exactly the SAME setup, the one working on hEx doesn’t work on hAP ![]()
I checked the server, hEx clients are connected, computers too, so the problem doesn’t come from the server I guess.
Any help please ?
Thanks in advance,
Nov/09/2018 09:48:42 l2tp,ppp,info l2tp-out1: initializing…
Nov/09/2018 09:48:42 l2tp,ppp,info l2tp-out1: connecting…
Nov/09/2018 09:48:45 l2tp,debug tunnel 25 entering state: wait-ctl-reply
Nov/09/2018 09:48:45 l2tp,debug,packet sent control message to 1.2.3.4.5:1701 from 0.0.0.0:1701
Nov/09/2018 09:48:45 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Message-Type=SCCRQ
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Protocol-Version=0x01:00
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Framing-Capabilities=0x1
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Bearer-Capabilities=0x0
Nov/09/2018 09:48:45 l2tp,debug,packet Firmware-Revision=0x1
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Host-Name=“fatest”
Nov/09/2018 09:48:45 l2tp,debug,packet Vendor-Name=“MikroTik”
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Assigned-Tunnel-ID=25
Nov/09/2018 09:48:45 l2tp,debug,packet (M) Receive-Window-Size=4
Nov/09/2018 09:48:46 l2tp,debug,packet sent control message to 1.2.3.4.5:1701 from 0.0.0.0:1701
Nov/09/2018 09:48:46 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Message-Type=SCCRQ
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Protocol-Version=0x01:00
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Framing-Capabilities=0x1
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Bearer-Capabilities=0x0
Nov/09/2018 09:48:46 l2tp,debug,packet Firmware-Revision=0x1
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Host-Name=“fatest”
Nov/09/2018 09:48:46 l2tp,debug,packet Vendor-Name=“MikroTik”
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Assigned-Tunnel-ID=25
Nov/09/2018 09:48:46 l2tp,debug,packet (M) Receive-Window-Size=4
Nov/09/2018 09:48:47 l2tp,debug,packet sent control message to 1.2.3.4.5:1701 from 0.0.0.0:1701
Nov/09/2018 09:48:47 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Message-Type=SCCRQ
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Protocol-Version=0x01:00
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Framing-Capabilities=0x1
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Bearer-Capabilities=0x0
Nov/09/2018 09:48:47 l2tp,debug,packet Firmware-Revision=0x1
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Host-Name=“fatest”
Nov/09/2018 09:48:47 l2tp,debug,packet Vendor-Name=“MikroTik”
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Assigned-Tunnel-ID=25
Nov/09/2018 09:48:47 l2tp,debug,packet (M) Receive-Window-Size=4
Nov/09/2018 09:48:49 l2tp,debug,packet sent control message to 1.2.3.4.5:1701 from 0.0.0.0:1701
Nov/09/2018 09:48:49 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Message-Type=SCCRQ
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Protocol-Version=0x01:00
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Framing-Capabilities=0x1
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Bearer-Capabilities=0x0
Nov/09/2018 09:48:49 l2tp,debug,packet Firmware-Revision=0x1
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Host-Name=“fatest”
Nov/09/2018 09:48:49 l2tp,debug,packet Vendor-Name=“MikroTik”
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Assigned-Tunnel-ID=25
Nov/09/2018 09:48:49 l2tp,debug,packet (M) Receive-Window-Size=4
Nov/09/2018 09:48:53 l2tp,debug,packet sent control message to 1.2.3.4.5:1701 from 0.0.0.0:1701
Nov/09/2018 09:48:53 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Message-Type=SCCRQ
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Protocol-Version=0x01:00
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Framing-Capabilities=0x1
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Bearer-Capabilities=0x0
Nov/09/2018 09:48:53 l2tp,debug,packet Firmware-Revision=0x1
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Host-Name=“fatest”
Nov/09/2018 09:48:53 l2tp,debug,packet Vendor-Name=“MikroTik”
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Assigned-Tunnel-ID=25
Nov/09/2018 09:48:53 l2tp,debug,packet (M) Receive-Window-Size=4
Nov/09/2018 09:49:01 l2tp,debug,packet sent control message to 1.2.3.4.5:1701 from 0.0.0.0:1701
Nov/09/2018 09:49:01 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Message-Type=SCCRQ
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Protocol-Version=0x01:00
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Framing-Capabilities=0x1
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Bearer-Capabilities=0x0
Nov/09/2018 09:49:01 l2tp,debug,packet Firmware-Revision=0x1
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Host-Name=“fatest”
Nov/09/2018 09:49:01 l2tp,debug,packet Vendor-Name=“MikroTik”
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Assigned-Tunnel-ID=25
Nov/09/2018 09:49:01 l2tp,debug,packet (M) Receive-Window-Size=4
Nov/09/2018 09:49:09 l2tp,debug tunnel 25 received no replies, disconnecting
Nov/09/2018 09:49:09 l2tp,debug tunnel 25 entering state: dead
Nov/09/2018 09:49:09 l2tp,debug session 1 entering state: dead
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: CCP close
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: BCP close
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: IPCP close
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: IPV6CP close
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: MPLSCP close
Nov/09/2018 09:49:09 l2tp,ppp,info l2tp-out1: terminating… - session closed
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: LCP lowerdown
Nov/09/2018 09:49:09 l2tp,ppp,debug l2tp-out1: LCP down event in initial state
Nov/09/2018 09:49:09 l2tp,ppp,info l2tp-out1: disconnected
