L2TP-Client On RouterOS For Forward Internet
hi to all
i have a problem
my RouterOS is RB433 and version is 3.25
my configuration :
ether1=local
address=1.1.1.1/24
wlan1=internet
address= 2.2.2.2/24
gateway=2.2.2.1
nat :
ip firewall nat add chain=srcnat action=masquerade
everything is ok and no problem
i have one vpn account for bypass filtering
l2tp-client :
interface l2tp-client add user=xxx password=yyy connect-to=“static valid ip address of my vpn provider” disabled=no add-default-route=yes
connected properly
now i need bypass all internet trafic by lt2p
but can not found any way for this
example :
now : desktop pc-> mikrotik-> internet
i want : desktop pc → mikrotik → l2tp ->internet
please help me
thanks
First of all try to add out-interface=wlan1 to your masquerade rule. Try to trace-route some internet addresses with L2TP tunnel established, perhaps that will help to find the problem.
dear
i do config my router in yesterday by mangle and work it very good
thanks for your answer :slight_smile:
