since I am not much experienced with Mikrotik, we have quite simple setup for VPN in our small office.
L2TP/PSK server on CCR with RADIUS accounting, CCR has a public IP on Ether1UPC interface so this should not be “NATed L2TP” variant AFAIK.
NAT only setup for other devices, FW only blocking remote SSH/DNS to router, IP pool has range from LAN.
This works on ROS v6 but not v7. Windows client does not connect with error 809.
Could anyone please advise? Thank You!
Relevant settings below:
add address=10.0.0.2/24 interface=bridge1 network=10.0.0.0
add admin-mac=4C:5E:0C:59:69:D1 arp=proxy-arp auto-mac=no name=bridge1 protocol-mode=none
add name=PPTPtest_pool ranges=10.0.0.91-10.0.0.99
/ppp profile
set *0 dns-server=10.0.0.230,10.0.0.236 local-address=10.0.0.2 remote-address=PPTPtest_pool
/interface l2tp-server server
set default-profile=default enabled=yes ipsec-secret=*** use-ipsec=required
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2
/ip accounting
set enabled=yes threshold=8192
/ip accounting web-access
set accessible-via-web=yes address=10.0.0.0/24
add action=src-nat chain=srcnat out-interface=ether1UPC src-address=10.0.0.0/24 to-addresses="public IP"
/ppp aaa
set use-radius=yes
/radius
add address=10.0.0.230 domain=internal secret=*** service=ppp src-address=10.0.0.2
