skkamal
November 27, 2017, 2:09pm
1
how connect l2tp client without user name on mikrotik router
exm:
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
local name lns
no l2tp tunnel authentication
exit
Link https://www.manualslib.com/manual/789223/Zte-Zxr10.html?page=119
pe1chl
November 27, 2017, 2:28pm
2
Cannot be done, MikroTik configures L2TP based on username.
skkamal
November 27, 2017, 2:47pm
3
Purpose Use this command to authenticate peers when the tunnel is configured
for negotiation.
Command Modes VPDN group configuration
Syntax l2tp tunnel authentication
skkamal
November 27, 2017, 2:48pm
4
And also please go through GGSN end configuration as GGSN is acting as LAC
Please find below the sample configuration at GGSN end
l2tp hello retransmit-attempts 3 retransmit-timeout 3 setup-timeout 40
l2tp lac-ip-address <xx.yy.zz.ww> vrf global host
l2tp lns-ip-address <aa.bb.cc.dd> string weight 100
l2tp lns-ip-address <ee.ff.gg.hh> string default weight 100
l2tp multi-lns normal
l2tp proxy disable
l2tp sequencing disable
l2tp session retransmit-attempts 3 retransmit-timeout 3 setup-timeout 60
l2tp tunnel-authentication disable
l2tp tunnel retransmit-attempts 3 retransmit-timeout 3 clear-tunnel-wait-timeout 3 setup-timeout 60
l2tp tunnel-id-number 2
l2tp tunnel-receive-window 20
pe1chl
November 27, 2017, 2:53pm
5
Those commands are for Cisco.
When the client side is on MikroTik, just put some dummy values in user and password and see how it goes.
For server side, it is not possible I think.
