L2tp disconnection time
I have a question about l2tp clients max connection time.
Is there any limit? I read that there is 8 hour limit.
My problem is that I have an RB3011 as main router and in this configuration I have a client connected to it using l2tp. The Problem is that at the client side I had to use not a mikrotik router but an Oxygen multi gateway.
The question is that the problem is caused because l2tp connection have a time limit ? Or probably something else? ( I have disconections at 24hours and with reboot everything is ok)
I am new to forum and sorry if the topic is not at correct place.
Thank you very much!
