Hello, I`m new in mikrotik configuration. I try to configure a L2tp VPN, when try to connect say error 789 and can´t connect.
I configured a PPT VPN and work fine, then I think that the firewall rules may be ok.
My configuration is:
aug/27/2018 18:35:03 by RouterOS 6.42.7
software id = 0ZG4-YIUP
model = RouterBOARD 952Ui-5ac2nD
serial number = 6CBA06D4E0F8
set [ find default-name=ether1 ] arp=proxy-arp name=ether1-Wan
set [ find default-name=ether2 ] arp=proxy-arp name=ether2-Lan
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=0s
pfs-group=none
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add name=vpn_pool ranges=172.16.0.1-172.168.0.20
add name=vpn_pool_l2tp ranges=10.10.0.1-10.10.0.20
add address-pool=dhcp_pool0 disabled=no interface=ether2-Lan lease-time=3d
name=dhcp1
/ppp profile
add dns-server=8.8.8.8 local-address=vpn_pool name=Vpn_Profile_PPTP
remote-address=vpn_pool use-encryption=yes
add dns-server=8.8.8.8 local-address=vpn_pool name=L2TP remote-address=vpn_pool
use-encryption=required
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=L2TP enabled=yes
ipsec-secret=testing use-ipsec=required
/interface pptp-server server
set authentication=chap,mschap1,mschap2 default-profile=Vpn_Profile_PPTP
enabled=yes
add address=192.168.1.1/24 interface=ether2-Lan network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=no interface=ether1-Wan use-peer-ntp=no
add address=192.168.1.0/24 dns-server=
190.160.0.15,200.30.192.14,200.83.1.5,8.8.8.8,8.8.4.4 gateway=192.168.1.1
add action=accept chain=input dst-port=1701 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input protocol=gre
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input protocol=ipsec-ah
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input disabled=yes dst-port=1701 protocol=tcp
add action=masquerade chain=srcnat src-address=192.168.1.0/24
/ip ipsec peer
add address=0.0.0.0/0 dh-group=modp2048 enc-algorithm=aes-256,aes-128,3des
exchange-mode=main-l2tp generate-policy=port-override local-address=
192.168.1.1 secret=test1
/ppp secret
add name=user2 password=test profile=Vpn_Profile_PPTP service=pptp
add name=user1 password=test1 profile=L2TP service=l2tp
/system clock
set time-zone-name=America/Santiago
/system routerboard settings
set silent-boot=no
/tool traffic-monitor
add interface=ether2-Lan name=tmon1 threshold=0
Can you help me to know what is the problem please?
Marco.
