My ISP has started to provide static IPs via a L2TP tunnel.
I have a RB750 and see that it has the L2TP interface available, however the ISP says the mikrotik wont work as they have been trying to do for quite some time. Apparently the mikrotik cant handle tunnel authentication? Sounds a bit arbitrary to me.
I haven’t tried myself because I am still waiting for my ADSL connection to be installed.
I suspect we might be using the same ISP. I am also having this issue. It is because they do not use IPSec with their L2TP implementation. Here’s the configuration specified by the ISP.
Please, if anyone knows how to get this working I’ll be plenty happy!
Connection Type Remote Access
Type Dial Out
Sever IP 196.30.121.50
Username Your DSL Username
Password Your DSL Password
Authentication Type PAP
Tunnel Authentication Yes
Secret h3lp
Active as Default Route Yes
IPSec No
