Hi, I’have RB951G behind RouterOS 6.42.1 and firmware version 3.33.
It’s behind cable modem from the cable TV. I’m struggling to make L2TP/IPSec VPN behind NAT. I have forwarded on the modem ports 1701, 8291, 4500, 500, 50, 51 and 47. Mikrotik has internal address 192.168.0.10.
Here’s configuration
/ppp profile
set *FFFFFFFE bridge=bridge dns-server=192.168.1.1 local-address=192.168.1.1
remote-address=default-dhcp use-mpls=no use-upnp=yes/ppp secret
add name=pnikolov password=“**********” profile=default-encryption service=
l2tp/ip firewall filter
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=accept chain=input dst-port=80 protocol=tcp
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input dst-port=8291 protocol=udp
add action=accept chain=input dst-port=1701,500,4500 in-interface=ether1
protocol=udp
add action=accept chain=input in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input in-interface=ether1 protocol=ipsec-ah
add action=accept chain=input in-interface=ether1 protocol=gre
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
/ip firewall mangle
add action=mark-connection chain=output disabled=yes new-connection-mark=
WAN1-conn out-interface=ether1 passthrough=yes src-address=192.168.1.0/24
WAN2-conn out-interface=ether2 passthrough=yes src-address=192.168.1.0/24
add action=mark-packet chain=input disabled=yes in-interface=ether1
new-packet-mark=WAN1-conn passthrough=yes
add action=mark-connection chain=input disabled=yes in-interface=ether2
new-connection-mark=WAN1-conn passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN1-conn disabled=
yes in-interface=bridge new-routing-mark=route_to_Mtel passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2-conn disabled=
yes in-interface=bridge new-routing-mark=route_to_4G passthrough=yes
add action=mark-connection chain=input connection-state=new disabled=yes
in-interface=bridge new-connection-mark=WAN1-conn nth=2,1 passthrough=yes
src-address-type=“”
in-interface=bridge new-connection-mark=WAN2-conn passthrough=yes
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat out-interface=ether2/ip ipsec peer
add dh-group=modp1024 enc-algorithm=aes-256,aes-192,aes-128,3des
exchange-mode=main-l2tp generate-policy=port-override passive=yes secret=
On the modem I have configured VPN passthrough - IPSec and PPTP.
ether1 is my primary WAN. I want to configure L2TP because of the better speed I have for transfers over OpenVPN and SSTP. When I try to connect with Windows VPN connection (Win 10) it says connecting… and it can’t connect. Where’s my mistake?
