I have one out of 10 L2TP/ipsec clients configured the same identical way to connect to same server , not able to encrypt when /ppp profile is set to use-encryption=required
All other clients have not any problem
Only this one gets an active connection if “use-encryption=yes” is set: this way, the field “encoding” is displayed blank in SERVER ppp active connections while the correct encoding is shown in CLIENT l2tp interface status…
Any idea please ?
This is log when encryption fails :
17:50:12 l2tp,ppp,info,account MYl2tp logged in, 172.16.219.12
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: sent CHAP Success id=0x1
17:50:12 l2tp,ppp,debug,packet S=D14BF281681468F01E4C999E2DB04BC012D58795
17:50:12 l2tp,ppp,info <l2tp-MYl2tp>: authenticated
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPCP lowerup
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPCP open
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: sent IPCP ConfReq id=0x1
17:50:12 l2tp,ppp,debug,packet <addr 172.16.219.254>
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPV6CP open
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: MPLSCP lowerup
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: MPLSCP open
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: sent MPLSCP ConfReq id=0x1
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: BCP open
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: CCP lowerup
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: CCP open
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: sent CCP ConfReq id=0x1
17:50:12 l2tp,ppp,debug,packet <mppe 1000040>
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: rcvd LCP ProtRej id=0x67
17:50:12 l2tp,ppp,debug,packet 80 fd 01 01 00 0a 12 06 01 00 00 40
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: LCP close
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: LCP closed
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: CCP lowerdown
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: BCP lowerdown
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: BCP down event in starting state
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPCP lowerdown
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPV6CP lowerdown
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPV6CP down event in starting state
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: MPLSCP lowerdown
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: sent LCP TermReq id=0x2
17:50:12 l2tp,ppp,debug,packet Encryption negotiation rejected
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: PPP received non-LCP packet (0x8021) when LCP not open
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: PPP received non-LCP packet (0x8281) when LCP not open
17:50:12 l2tp,ppp,debug,packet <CLIENT_PUBLIC_IP>: rcvd LCP TermAck id=0x2
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: LCP lowerdown
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: CCP close
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: BCP close
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPCP close
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: IPV6CP close
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: MPLSCP close
17:50:12 l2tp,ppp,info <l2tp-MYl2tp>: terminating... - Encryption negotiation rejected
17:50:12 l2tp,ppp,debug <CLIENT_PUBLIC_IP>: LCP down event in initial state
17:50:12 l2tp,ppp,info,account MYl2tp logged out, 1 28 24 4 3
17:50:12 l2tp,ppp,info <l2tp-MYl2tp>: disconnected
17:50:12 l2tp,debug,packet rcvd control message from CLIENT_PUBLIC_IP:1027 to 10.0.10.254:1701
17:50:12 l2tp,debug,packet tunnel-id=28220, session-id=1, ns=4, nr=2
17:50:12 l2tp,debug,packet (M) Message-Type=CDN
17:50:12 l2tp,debug,packet (M) Result-Code=1
17:50:12 l2tp,debug,packet (M) Assigned-Session-ID=1
17:50:12 l2tp,debug,packet sent control message (ack) to CLIENT_PUBLIC_IP:1027 from 10.0.10.254:1701
17:50:12 l2tp,debug,packet tunnel-id=45, session-id=0, ns=2, nr=5
17:50:12 l2tp,debug session 1 entering state: stopping
17:50:12 l2tp,debug session 1 entering state: dead
17:50:12 l2tp,debug,packet sent control message to CLIENT_PUBLIC_IP:1027 from 10.0.10.254:1701
17:50:12 l2tp,debug,packet (M) Message-Type=StopCCN
17:50:12 l2tp,debug,packet (M) Assigned-Tunnel-ID=28220
17:50:12 l2tp,debug tunnel 28220 entering state: stopping
17:50:12 l2tp,debug,packet rcvd control message (ack) from CLIENT_PUBLIC_IP:1027 to 10.0.10.254:1701
17:50:12 l2tp,debug,packet tunnel-id=28220, session-id=0, ns=5, nr=3
17:50:12 l2tp,debug tunnel 28220 entering state: dead
